586,113 active members*
3,118 visitors online*
Results 1 to 7 of 7
    Jul 2011
    Laser for 1/2" plywood
    I am looking for a suitable laser head that will cut through 1/2" plywood ( Italian Polar and Baltic Birch )
    What amount of power do you recommend and are there any brands of laser heads I should consider/avoid?
    Yes, I know I will have charred edges, that's of no concern. I also have compressed air, a means of removing smoke and CO2 if necessary.
    Dec 2008
    1258
    100W would be marginal and depends on the epoxy (glue) and other resins in the wood, so I would suggest 120W+ (this is based on Chinese glass tube CO2 lasers).
    If you are considering a higher end machine, with something like the Synrad RF excited metal tube laser you would be ok with 80W+.
    You can usually trade speed for cut depth, or use multi-pass but as you already know this isn't ideal on wood and will result in very charred edges.
    If you are going to be doing mainly 1/2" and above, a 400W+ system would be recommended.
    Zax.
    When I was at shenui laser in China , I saw they had dual laser systems for cutting and manufacturing thick die board , there are 2 x 150w glass tubed lasers , one firing at the top and the other at the bottom of the boards , these would be ideal for cutting 1/2" plywood imo.
    Jul 2011
    Quote Originally Posted by zax15uk View Post
    100W would be marginal and depends on the epoxy (glue) and other resins in the wood, so I would suggest 120W+.
    That's what I was thinking would be minimum - even 135W. Can you recommend a brand and what are those Chinese CO2 glass lasers like?
    Quote Originally Posted by Rodney Gold View Post
    What is their quality, reputation etc like?
    Excellent machines , excellent service , excellent tech support.
    Read my threads...
    Chinese lasers - they're here !!!!!!
    and
    Despatches from China
    on further reflection I think the dual up and down firing lasers might not be ideal for cutting , they were lasering die board, dunno what would happen to the cut piece....
    Jul 2011
    Read my threads...
    and
    Thanks Rodney - this is the sort of info I am after.
    I am going up to China to buy some machinery for the company I work for so I just might visit these guys and see what they have to offer.
    Cheers
    Feb 2011
    Just as a point of reference, I just got a 80W CO2 laser, I can cut 1/2" solid pine no problem, but I can barely cut the 1/4" plywood I got at the same speed. I think it's because it's "Exterior" plywood, if you look at the edge, you can see black layers of glue. I'm looking for some other types with less glue / coatings, under the theory that they'll cut better.
  1. 50" x 100" Plywood gantry router
    By Yehuda in forum Open Source CNC Machine Designs
    Last Post: 08-14-2015, 05:22 AM
  2. cutting plywood w/ a laser
    By sthole in forum WoodWorking Topics
    Last Post: 09-13-2011, 09:38 AM
  3. Alternative to "laser" branded plywood?
    By Solexious in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-28-2010, 01:52 AM
  4. UK Laser plywood supplier?
    By KPBadger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-26-2010, 05:25 PM
  5. 80W Laser 3/4" Plywood cutting speed
    By coleclan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-18-2007, 07:49 PM
