586,036 active members*
3,952 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D - Undersized cuts on profiles
Results 1 to 10 of 10
    Feb 2007
    473
    Hey all!
    I bought Vectric Cut2D a few days ago and have been having a weird problem with it...
    If I create a square that is 4"x4" and then create an outside profile toolpath for it, the square consistently comes out at 3.95"x3.95".
    I'm cutting MDF and I initially thought this was something to do with the material, but upon double checking any pockets cut are the right size to a tolerance of about .004
    If I create an inside profile toolpath for the same 4"x4" square I get a cutout that is 4.05"x4.05"...
    I'm really not sure why this would be happening, the tool setup is correct and I can't seem to see any other problems. The fact that the pockets are the right size is the weirdest part...
    Anyone have any idea about what might be going on?
    Tool deflection or machine flex, maybe? Try cutting in the opposite direction and see if the size changes?
    Also, let me see the code for a 4" square.
    Feb 2007
    473
    Thanks for the response Gerry.
    I also thought it might be something like tool deflection... But in that case I would expect to see the same deflection in pocketing toolpaths as well, and so far I have not been.
    I'll copy in the generated G-Code when I get home tonight.
    Aug 2005
    597
    Quote Originally Posted by aarongough View Post
    Hey all!
    Hello Aaron,
    Could the cutter be slightly larger than the diameter specified in the software?
    For example, if the actual cutter diameter is 0.050” larger than the dia specified in the software. When cutting around the outside of the vector, the result would be to overcut by 0.025” on each side of the 4” x 4” square when run on the machine = 3.950” x 3.950” undersize by 0.050”
    When cutting the internal pocket inside the vector, the tool would also overcut by 0.025” per side = 4.050” x 4.050” oversize by 0.050”
    Spindle run-out could also be another reason for the overcutting??
    Maybe machine along a line and measure the width of the groove to see if this matches the diameter of the cutter.
    Tony
    Feb 2007
    473
    Tool deflection and runout
    Gerry & Tony: Thanks for your responses.
    I did a series of test cuts this morning to see if I could work out what the issue is. I've attached a photo of the cuts and the measurements I took from them.
    The issue looks to be a combination runout & deflection. I hadn't realized exactly how much flex was in my router... (Luckily I can hand off the blame for that as it was built from a kit)
    A slot cut using a .125" endmill measures at ~.140", which I would attribute mainly to runout given that my spindle is a Dremel. There is also tool deflection visible when the cut changes from plunging to XY movement. I measured the deflection at ~0.038"
    So I assume I can compensate for the runout to an extent by setting the tool width to equal the measured slot width, however I am confused by the fact that the circular pocket cut is within tolerance at .505"
    The tool deflection is starkly illustrated in the attached image by the difference between the two halves of the slot at the top of the image. One side was milled conventionally and the other was climb milled.
    Any tips you guys have for compensating for the shortcomings of this machine would be great. I'm part way through the build of a new machine to replace this one, but I had anticipated using this machine to make parts, which now looks like it may be not such a great idea.
    Thanks again!
    -Aaron
    Feb 2007
    473
    Aftermath & Solutions
    So I've spent the afternoon making test cuts with different paramters to see if I can find the sweet spot for this machine and material.
    The test cuts in the photo above were made with a .08" DOC @ 12 ipm. That may sound slow but remember I have a *very* flexy machine...
    After numerous test cuts I have managed to get a near perfect result with these settings: 0.015" DOC @ 42ipm. I also adjusted the tool diameter to match the diameter that I measured from test cuts which was .143" (from a .125" endmill! Talk about runout.)
    With these settings I am able to get profile cuts to within .001" of the expected size, which is good enough for the work I'm doing.
    The much smaller Depth Of Cut also seems to completely remove the tool deflection I was experiencing earlier.
    Pockets are another matter though as they are consistently turning out .02" undersized. Compensating by making the pocket in the CAD drawing .02" oversized yields a result to within .001" tolerance, but seems a little hacky.
    If anyone has a suggestions about possible causes of the undersized pockets I would love to hear them!
    Apr 2010
    aarongough, is that a Dremel 300? The runout sounds awfully like my experience.
    I found that 30-40ipm (depending on wood type) and .04" DOC was right for me.
    Feb 2007
    473
    Quote Originally Posted by Ron Dunn View Post
    Hey Ron!
    I'm using a Dremel 4000, but obviously it isn't great either. I'm looking forward to upgrading to a Bosch Colt on my upcoming machine, that's for sure!
    Feb 2007
    532
    One thing I found with my Dremel was packing out the bearings in the casing helped the runout/slop/wobbles quite a bit.
    I thought it was bearing runout, but it turned out the bearings were fine, but the upper one was actually moving around inside the case. Mine is a 395
    Something easy to check anyway...
    Feb 2007
    473
    Quote Originally Posted by kiwichris View Post
    Thanks for the tip! I will definitely check that out.
    I'm already part-way through the build of a better machine that will use a Bosch Colt as a spindle, so hopefully that will help get me away from these problems in the future.
  1. CNC Plasma undersized ID's
    By madkins in forum Waterjet General Topics
    Last Post: 05-22-2008, 04:17 PM
  2. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  3. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
  4. Is 12mm/2mm ballscrew for Z-zixs router undersized?
    By NC_jimbo in forum Linear and Rotary Motion
    Last Post: 03-26-2007, 08:24 AM
  5. X2 spinle undersized?
    By AirHog in forum X3/SX3/G0619/G0463
    Last Post: 02-19-2007, 01:09 AM
