You'll need power hooked up to the machine to insert the counterweight lock. If the machine is already on the way its too late for that.
It shouldn't take very long to dismount the motor. What year is the machine? I'm assuming it's DC servos...if so, remove the 4 bolts and lay the motor down. You don't need to disconnect the motor, just remove it from the mount. You'll also need to knock over the Gortrac (gray or black conduflex runs from the column to the head). Loosen the bolts and lay it on its side to clear your garage.
You'll probably also need to put in a single phase transformer/phase converter unless you have three phase in your garage. We recommend the single phase transformer since it replaces your existing transformer in the back cabinet, saves space, and is normally more cost effective. Contact us if you need more information about this.
We had a 4020 in our garage for awhile for testing purposes. If you need any help at all, feel free to give us a call or send me an email.
-Shelvin
TheFadalParts.com
(818) 678-9456
Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
