586,075 active members*
4,164 visitors online*
Thread: Circuit Help
Results 1 to 10 of 10
    Nov 2004
    239
    Circuit Help
    I'm working with this circuit.
    http://www.aaroncake.net/circuits/stepper.htm
    To make it step am I supposed to apply 12 volts to the step line between 3 and 13?
    Does this look like a pretty good circuit to be learning from?
    Aug 2005
    73
    hmm, really odd, pin 3 and 13 are indeed marked as "step", but the connections are
    not labelled in the chip, so i don't know what they do.
    just a few observations:
    -you will need motors with a tap in the middle of each coil (i.e: 6 wire step motors,
    while many (most?) step motors have only 4 wires.
    -the S1 switch is only connected to inputs, so that wire will work as an antenna if
    it's in the middle of the switch (i.e: rattle between + and - at a few MHz), tho the
    rest of the electronics may take care of this, it's still better to avoid.
    A more conventional way is to connect the input via a (10k) resistor to +12V and
    then just a single switch to pull it down to 0V. (i.e: switch open: +12V.
    switch closed: 0V)
    -this circuit cycles through the 4 possible motor stages, but there is no reset, so you
    (or the computer that is generating the steps does not know what the initial stage is)
    What are you trying to do?
    Do you want to drive the step motor from a printer port of a computer?
    What kind of step motor do you have ?
    jaap.
    http://jwstolk.xs4all.nl/mill.htm
    Aug 2005
    1622
    That is what it shows.
    Here is a data sheet on the Fairchild CD4027
    Pins 3 and 13 are the clock lines for each flip-flop.
    DC
    Aug 2005
    73
    every time the "step"wire changes from 0V to 12V it will do a single step.
    Nov 2004
    239
    I'm working with the parallel port and visual basic. Electronics are a new subject to me. I have a breakout board with led's and I'm using visual basic to understand the output of the parallel port.
    I've assembled that circuit on a breadboard with led's instead of a motor to see if I can get some output. So far no luck.
    Aug 2005
    73
    Ty connecting the "step" wire to +12V using a 10k (or similar) resistor, and then use a wire to
    conenct it to 0V (at the same time) to generate the step pulses.
    do any of the LED's light up ?
    see also my breakout board of my motor driver: :-)
    http://jwstolk.xs4all.nl/i/proptotyp...tor_driver.jpg
    Aug 2005
    1622
    This was posted in another thread a few days ago. It gives a decent tutorial on using Qbasic and the parallel port as a control means.
    Bits to Bytes
    The output of most parallel ports are 5v, not 12v. I doubt this will work to trigger this circuit.
    If you are completing the circuit with the transistors installed and still driving LED's. I would guess the LED's could be blown unless you put a 2K resistor in line with it. No need for the transistors. You should be able to connect the 2K resistors(in place of the 1K resistors) to the LED's anode (longer lead) and the LED's cathode(by the flat side of the case, shorter lead) to ground in place of the stepper motors. Using 4 LED's, with one at each resistor simulating the stepper phases.
    This same circuit could be created using similar TTL IC's instead of the CMOS so it could operate on 5v. The resistor values would be cut in half too.
    DC
    Jun 2003
    3312
    This is generally the same circuit as the discrete board on my wedsite: http://pminmo.com/discrete/discrete.htm
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2005
    73
    Quote Originally Posted by Shanghyd
    i have registerd for ICQ and we spend some time testing/debugging.
    the non-working led's have been traced to a broken 4027 chip and the 4000's not being
    able to drive the LED's directly. so things are on the move again :-)
    jaap.
    May 2005
    12
    Hi all, are there any Australians on this site? Our local electronics mag publishes stepper motor controllers from time to time, and a similar circuit to the above is provided on their web site. http://www.siliconchip.com.au/cms/A_100994/article.html
    Cheers
    Happymacer
