Hello,
The flash drive that came with the VF2 just stopped working, so I need to make a back up of the parameters of that machine.
Does anyone knows how to do that?
Thank you
jolulank
Hello,
Thank you
jolulank
In the newest software version:
1. Insert new USB
2. Go to List Prog
3. Select USB
4. Type a file name (Serial number and model=good choice)
5. Press F4
6. Highlight "Save All"
7. Press Write/Enter
8. You should have several file names with different extensions.
note: If you want to backup the probing files and other 9000 series programs, you need to turn off setting 23. You can turn it back on after the copy.
Ken Foulks
I already did backup the parameters with the info you sent me.:banana:
Jolulank
http://www.cnczone.com/forums/images/smilies/banana.gif
