586,072 active members*
4,714 visitors online*
Page 9 of 9 789
Results 161 to 167 of 167
  1. #161
    Mar 2006
    Thanks allot Erik...
    Ya when I press the unlock button the solenoid will not engage at all, but the lock button works the draw bar just as it should....
    I will take off the side panel and jumper the button....
    It looks like there are a couple semiconductor things inside the small access box where all the way lube, limit switches, and solenoids are wired together.
    There is one for each solenoid....don't have a clue what those little rectangular plastic things are but if the button is working, could it be one of those gizmos?
    I believe the air impact is operating properly. There is no clicking at all of the solenoid when the button is pressed...
    But I will start with the button....
    Murlin
    edit....yes I thought about starting my own thread but this place is so huge I did not know if it would get any response.
    you had my exact mill and seemed to know more than anyone so thanks for the feed back...
  2. #162
    Sep 2005
    322
    Do this: First, start a new thread here, in this section of the forum.
    Then, take pictures of the parts you're talking about and upload them - we can then tell you what those components are. From your description, they might be solid state relays. If the buttons don't work, then yes, it could be one of those. However, start with the buttons
    Erik
  3. #163
    Mar 2006
    Will do man and thanks !
  4. #164
    Jul 2012
    8
    Hey Eric, I finally started my thread and put some pics up. I'm sure there is a better and more appropriate way to send you a link without interrupting your thread but I haven't found it yet. I'm excited to see how close you are getting and although I think our projects are a little different (Mach v Linuxcnc and some different components) I've learned a bunch from this thread. Anyways take care and check out my thread lagunmatic 310 cnc knee mill retrofit to PC control whenever it convenient!
    Thanks!
  5. #165
    Dec 2010
    Re: Pics and plans
    What happened to all the images?
  6. #166
    Sep 2005
    322
    Re: Pics and plans
    Quote Originally Posted by caracadon View Post
    My image hosting is down. I'll check to see if I can find somewhere to put the images and restore them from a backup.
    FYI, I'm currently getting ready to build another revision to my mill, a new control panel.
    Erik
  7. #167
    Oct 2021
    Re: Lagunmatic CNC 250 refurb
    Quote Originally Posted by michaelthomas View Post
    A machinist friend of mine has a Lagunmatic 320 that he got from an auction nearly 15 years ago. It has not been powered up since. The arid climate here in Colorado has appeared to have been kind to it over the years. It has the Dynapath controller as well.
    He has done me a lot of favors, so I'm gonna try to get it up and running for him. I have the manuals for the machine and the control if that would be helpful to you.
    Good afternoon!
    I’m pretty sure you just saved my day. I have been searching high and low for the machine installation service and maintenance manuals for this CNC. Is there any way that you could send me the part of the manual that focuses on the head assembly for the Lagunmatic 320? I am getting ready to reassemble the head assembly (that an inexperienced operator has unfortunately removed along with the motor) and I have been trying to research it as I have absolutely no idea what I have gotten myself into. More specifically I need any information that you have on the spindle assembly I.e: Parts list, blown schematics, drawings, anything will help at This point. Because I was not the one to disassemble, Before moving forward with this project I want to be sure I’m not missing anything. It looks pretty straightforward but I’m not one to rush into a rebuild without any information.
    Anything that you have that would help me out would be greatly appreciated! Thank you for your time and I hope you have a wonderful day!
    Jenni
Page 9 of 9 789
  1. DIYENGINEER Ex-Boeing Plasma CNC refurb.
    By diyengineer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-15-2013, 11:54 AM
  2. Refurb or Reconditioned Bridgports
    By Gensor in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2013, 02:21 AM
  3. Ok all you smart guys!! lol need some help! Refurb !!!!
    By dhj2003 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2011, 01:53 AM
  4. Laser Pro Neptune Refurb Advice/Help
    By DRP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-28-2011, 08:24 PM
  5. Lightmachines/Spectralight refurb
    By RepairmanSki in forum Benchtop Machines
    Last Post: 08-10-2006, 04:41 AM
