TNC410
So at the end of a part when it should be a z rapid up the machine quits. On restart z axis will not home flashing error movement error A
Lights on axis drive[Siemens] are all fine
changed parameters to home z last, other axis home fine. swapped the z axis brake relay as a wild guess with no effect.
control counts a few thou if you slow it down when it tries to home, but have not confirmed it is actually moving .
There do not appear to be any fuses etc after the drive per the wiring diagram, so I guess it is time to pull the motor off of the top
I have another machine just like it but with extended z travel, I could swap the motor, but it has work to do too....
Ideas?
