586,100 active members*
2,805 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Need Help Choosing a Stepper, Driver, and Contorller Kit
Results 1 to 6 of 6
    Feb 2011
    Hey everyone,
    I'm just getting into the CNC world and am just about ready to build my first 3 axis Router, but I'm having a hard time choosing a kit with steppers and drivers with the breakout board and power supply. I have looked at a few like the ones from probotix. My main question is what kit would work best for my 40x30x5 machine that uses a wood router.
    Any help or advice on anything cnc is greatly apreciated.
    Thanks in advance
    Mar 2010
    collect more information, you will get more experiences. We have Yako driver and Chinese good stepper motor.
    Jul 2011
    Hi, I'm also just starting out, I've done a fair bit of research and I'm pretty confident I'm going to get it all sorted out, but first I want to plan it all well. HobbyCNC | CNC for the desktop machinist and hobbyist. is run by a guy called dave I think; that's where I plan to get my driver board from at least. The one you will typically get off ebay suffer from missed steps, and as such you won't get too much in the way of accuracy from your machine.
    What software are you planning on using? I'm a student so everything is as cheap as I can make it, so the emc project from LinuxCNC.org - Home is my way to go being free and all.
    From waht I could tell about probotix, they seemed rather overpriced. hobby cnc and emc have fairly good reputations on cnczone. Of course the hobby cnc driver has it's problems what with being only unipolar drive. www.easy-cnc.com * Your best option in driver boards for CNC machines had a cheap bipolar board which I may use, but I wasn't able to confirm it's reputation... (Unipolar gives a lower torque than the bipolar modes of operation, as you're going to be using wood, shouldn't be too much of a problem.)
    I'm just going to go for a cheap power supply off ebay. probably 36V 15A...
    lastly google "CNCMechanics v1.2" to find the pdf, it should be exactly what you want to know about doing the calculations if you have a technical background, I'm and engineering major, so I feel as if I have to do calcs before jumping.
    Good luck
    Oct 2008
    406
    Quote Originally Posted by Manicalistical View Post
    I realize you're trying to keep the cost down, but a cheap power supply can give you all sorts of problems. From erratic operation to blown drivers. Just a friendly heads-up.
    Bob
    "Bad decisions make good stories."
    Mar 2008
    161
    I'd lurk around for a little and read up on other people's builds. I've gotten some great ideas and advice just cruising through other people's projects.
    As for starting out, I used Keling Inc. Drivers and a SmoothStepper control board. I had a good experience with them.
    Best advice I can give you is that if you cut corners, you will spend more time correct the problems that creates than just taking the time to do it right in the first place.
    Jul 2011
    Quote Originally Posted by bobsch View Post
    Yes I realise and I am rather worried about it, to compensate I was going to stick with a 36V power supply on a driver which is rated to 42VDC, I'm hoping a spike of 6V is out of the question. Though maybe at startup when closing a switch... Anyway what would you suggest?
  1. Choosing a Driver Board and Power Supply
    By HomemadeCody in forum Stepper Motors / Drives
    Last Post: 11-30-2010, 12:43 AM
  2. Need help choosing a servo driver
    By scrambled in forum Gecko Drives
    Last Post: 11-15-2008, 07:15 AM
  3. shizuka cnc mill, Yasnac contorller
    By chuckbuck in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-01-2008, 04:43 PM
  4. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  5. Choosing a driver
    By yorttroy in forum CNC Machine Related Electronics
    Last Post: 06-15-2004, 06:28 AM
