586,971 active members*
2,995 visitors online*
    Jun 2003
    176
    Cutting Aluminium
    Question
    I am almost completed with my 4X8 router (see pics in homebuilt machines forum under my screen name)
    If I want to cut something out of aluminium - which will not be very often...... can I ?? The machine has (will have) a 3.25 HP Porter cable router spindle
    What RPMS are best, and feed rate to cut ?? I may try to cut something out of some 1/4" - 3/8 plate so I was curious if I could..... and what I should look out for etc...
    Thanks for any input guys !
    Apr 2003
    292
    What is your max spindle speed? I'm guessing that your machine will be well suited for high speed machining of aluminum. Although I'm not very well versed in high speed machining, I've heard of people machining aluminum at spindle speeds of 20,000-60,000 RPM with ungodly feed speeds.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    Apr 2003
    1876
    Yes you can. Keep it wet, higher RPMs generally better. You may need to take light cuts with only 3.25 hp, just start slow and work up til you start bogging the motor down, then back down about 10% or so.
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1079
    I'm no expert here, but if you are going to be using small cutters (less than 1/4") then may I suggest a single flute, high helix type as these will help eject the chips and prevent snapped bits (snapped bits, now that, I know about!)
  1. Newbie question: Cutting aluminium
    By RAN in forum MetalWork Discussion
    Last Post: 05-16-2005, 03:48 AM
  2. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 06:14 AM
  3. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
  4. Cutting aluminium tube
    By cnczoner in forum MetalWork Discussion
    Last Post: 07-09-2004, 11:06 PM
  5. Router bits. ( Aluminium veneer )
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-12-2004, 04:49 PM
