586,113 active members*
3,293 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Boolean Subtract Not working with STL Model
    Apr 2005
    1268
    Hey Guys! (Also posted on Bobcad Forum) This is Version 23.
    Another problem. I imported an STL model of a Crest inside a dish which is "sunk" in a square Z plane. I want to delete the square part and end up with the circular bowl and crest carved on the interior of the bowl. I attempted to get rid of the square part of the model by creating a cylinder the Id of which is the OD of the circular part of the bowl intersected midway through the crest on the z plane. I then attempted a boolean subtract to get rid of all but the bowl. It just won't do it. It seems to be doing something then back to the original screen. Nothing changes. The two solids (cylinder and crest model) remain unchanged and are still two separate entities. I even tried a boolean add and still not luck. Nothing changes.
    I'll attempt to add a zipped file of the model and any help will be appreciated.
    I can't believe that this software won't do an easy subtraction.
    Thanks in advance.
    Bill
    Attached Files Attached Files
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Feb 2009
    2143
    I don't think you can use Boolean tools on STL files. They are just surfaces, even if totally enclosed, on the "other" side of the face is a "hollow" part. They are NOT solids. Boolean needs solid parts to interact with.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Apr 2005
    1268
    Thanks mcphill. That makes sense!
    Bill
    billyjack
    Dec 2008
    4548
    STL's can be "solids" and defined so..
    It's just that BobCads Geometry tools dont work on Polygon data. Only the toolpaths do.
  1. boolian subtract not working
    By missing link in forum BobCad-Cam
    Last Post: 04-24-2011, 03:12 PM
  2. Boolean Subtract, can't get it to work.
    By cjdavis618 in forum BobCad-Cam
    Last Post: 11-22-2010, 02:53 AM
  3. V22 Boolean Subtract
    By TZ250 in forum BobCad-Cam
    Last Post: 12-03-2008, 08:11 AM
  4. WORKING Ferrari 312 PB replica scale model
    By FPV_GTp in forum I.C. Engines
    Last Post: 10-25-2007, 08:46 PM
  5. Miniature/model scale working
    By arvindk in forum Uncategorised MetalWorking Machines
    Last Post: 01-15-2007, 01:33 AM
