586,096 active members*
3,112 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Help with a transformer question
    Jun 2008
    27
    Just got an HiT 18S and have a question. It was wired for 480 and what I have available is 220. Doesn't seem to be a problem except that the book says the Siemens spindle drive requires 400v. Does this mean I have to get a step up transformer just for the spindle drive? Everything else seems to be fine with 220.
    PS. it had a step down transformer from 480 to 400/220/110v
    24221
    If the voltage configuration for the 480/220 is in the machine enclosure, then this is most likely taken care of inside the machine.
    You would only have a problem if the machine was declared 480 supply only.
    Al.
    Albert E.
  1. Transformer Question
    By Bimmerkc1 in forum CNC Machine Related Electronics
    Last Post: 01-15-2007, 10:15 PM
  2. Transformer question need help!
    By northernmach in forum DIY CNC Router Table Machines
    Last Post: 11-30-2006, 11:51 PM
  3. Transformer question
    By pstockley in forum CNC Machine Related Electronics
    Last Post: 04-05-2006, 05:13 AM
  4. Transformer question
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 08-13-2005, 03:55 PM
  5. Transformer Question
    By SJ781 in forum CNC Machine Related Electronics
    Last Post: 11-05-2003, 02:39 PM
