586,103 active members*
3,339 visitors online*
IndustryArena Forum > CAM Software > CamBam > Edit dxf and update in cambam
    Mar 2006
    38
    Question Edit dxf and update in cambam
    Is it possible to make miner changes to the drawing and have cambam update the saved cb file with the new dxf?
    Grandpa Jay
    Feb 2005
    521
    Quote Originally Posted by grandpa jay View Post
    Grandpa Jay
    Not exactly... It is something we're considering, that is 'linking' to a DXF file, rather than importing all the objects.
    For now, what you can do is this...
    Open your CamBam drawing.
    Start another instance of CamBam and into this load your revised DXF file.
    Copy the changed parts of your DXF to the clipboard then paste them into your CamBam drawing. You may want to delete the changed parts from your CamBam drawing first.
    You then need to relink your machining operations with your changed drawing objects. There are a few ways to do this.
    Right click the machining operation then select 'Select drawing objects'
    or
    Change the IDs in the Primitive Id list property of the machining op.
    or
    Select the new drawing objects then drag them in the drawing tree, onto the machining operation icon.
    I tend to use the last method the most.
    I hope this helps.
    www.cambam.co.uk
    Mar 2006
    38
    Thank You
    For now I will just redo the part. It's not a complicated part.
    Grandpa Jay
  1. CamBam
    By ckjk616 in forum CamBam
    Last Post: 10-28-2010, 11:19 AM
  2. CamBam 0.9.8
    By blowlamp in forum CamBam
    Last Post: 10-12-2010, 10:43 AM
  3. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  4. Need Help With CamBAM
    By Ponchibego in forum CamBam
    Last Post: 08-01-2008, 03:49 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
