586,121 active members*
3,330 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet OSP700 alarm 1055-20
Results 1 to 5 of 5
    Jan 2007
    5
    I am getting alarm #1055-20 Alarm A "VAC Power Circuit Low Voltage" when I power the machine up. After the alarm on the controller I get alarm 17 on the VAC Drive. Is it a problem with the VAC drive or power to the drive and how can I check?
    Dec 2008
    3109
    First check to see if any of the 3 phase fuses are tripped on the power supply board before it comes into the machine
    Jan 2007
    5
    3 phase power is all good, i have checked all fuses in the machine and on the drive and everything is good.
    Oct 2010
    103
    Quote Originally Posted by b1apt View Post
    Do ya have any books on that? I'd power it up and check power if you haven't done that. Checking fuses may not reveal the problem. Could it be a contactor maybe? Just tossing thoughts. If you have the key for the door interlock, you should be able to fully power and operate with the door open
    Aug 2013
    3
    Did you ever figure this out ?
    I’m having this problem too.
  1. How to run chip belt on Okuma LCS15 + OSP700?
    By testpilot in forum Okuma
    Last Post: 01-15-2014, 10:16 PM
  2. Okuma Cadet 999 Alarm A
    By MTIjake in forum Okuma
    Last Post: 12-11-2013, 07:32 PM
  3. Okuma Cadet LNC8 Alarm
    By 3DDonn in forum Okuma
    Last Post: 08-21-2013, 05:15 PM
  4. Okuma Cadet Graphing
    By Kart 34 in forum Okuma
    Last Post: 01-30-2008, 04:05 PM
