586,103 active members*
3,557 visitors online*
IndustryArena Forum > CAM Software > Vectric > Can you put more information in File Header?
    Nov 2006
    1036
    When I create a file for Mach 3 from Aspire, it automatically makes a file header stating "( File Created by VCarve Pro)".
    Is there a way to put more information in the file like?:
    cutting tool
    feed rate
    etc.
    Aug 2005
    597
    Hi Don,
    The default Mach3 postp saves the following information into the header of toolpath files,
    begin HEADER
    "( [TP_FILENAME] )"
    "( File created: [DATE] - [TIME])"
    "( for Mach2/3 from Vectric )"
    "( Material Size)"
    "( X= [XLENGTH], Y= [YLENGTH], Z= [ZLENGTH])"
    "([FILE_NOTES])"
    "(Toolpaths used in this file: )"
    "([TOOLPATHS_OUTPUT])"
    "(Tools used in this file: )"
    "([TOOLS_USED])"
    "[N]G00G20G17G90G40G49G80"
    "[N]G70G91.1"
    "[N]T[T]M06"
    "[N] ([TOOLNAME])"
    "[N]G00G43[ZH]H[T]"
    "[N][S]M03"
    "[N](Toolpath:- [TOOLPATH_NAME])"
    "[N]([TOOLPATH_NOTES])"
    "[N]G94"
    "[N][XH][YH][F]"
    Additional information can be added and this is explained in the postprocessor manual - See > Postprocessor Guide
    If you need help please drop a note to - [email protected]
    Tony
  1. Tool list in header
    By MILLMANM in forum Mastercam
    Last Post: 02-13-2010, 04:02 PM
  2. Pin out for Header
    By Mr. LocoMartin in forum Stepper Motors / Drives
    Last Post: 12-08-2009, 04:32 AM
  3. .1" header adapters?
    By realsquash in forum CNC Machine Related Electronics
    Last Post: 07-10-2008, 01:05 PM
  4. does anyone have a good information source .pdf file...
    By brianklein in forum MetalWork Discussion
    Last Post: 03-28-2008, 05:25 AM
  5. Need header tubes bent
    By RickDLance in forum Bending, Forging, Extrusion...
    Last Post: 02-16-2008, 04:57 AM
