586,119 active members*
3,635 visitors online*
    Feb 2006
    10
    PROGRAM DIRECTORY LISTING
    I am trying to get the program directory listing to copy to floppy or usb. I am able to get a disk directory from the floppy or usb but I need it the other way around.
    James
    Oct 2004
    158
    I think you may need to enter, in a command window, DIR > A:\filename.txt
    and of course you can add various DIR commands, perhaps give the path to the directory you want listed if you're not 'in' it at the command prompt... change the A:\ to the USB drive...only list files, not sub-directories...
    A DIR /? will give you a list of the available commands for DIR
  1. UL Listing?
    By kimoyo in forum Excitech routers
    Last Post: 08-15-2009, 05:32 AM
  2. Mori NV5000, program directory (available memory)
    By teal854t in forum Mori Seiki Mills
    Last Post: 07-31-2009, 02:57 PM
  3. Opps Deleted directory
    By classictom in forum HURCO
    Last Post: 04-12-2008, 12:47 AM
