How do you machine a pocket with 1 or 2 edges open in bobcad v23?
I have played around an the best I can come up with is extending the part geometry by the diameter of the cutter at the openings
Currently extending the part is correct , it is the only way.
For those of you that have read this thread and are wanting to know how to machine an open pocket I have found an easy solution.
After a bit of web searching and watching the training video's I found the easiest way to do open pockets is with High Speed Milling. Just change the open side's of the pocket to a dashed line and Bobcad will automatically know that this is an open edge and the tool can pass through the dashed line.
Very cool it works well.
High speed pocketing,which I believe is not offered anymore.But yes,that is the best way to do open pocketing if you have that option.
