586,446 active members*
3,720 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Chuck high low pressure
    Oct 2009
    114
    Any one using chuck high low pressure control.
    From high pressure to low pressure. When low pressure is effective.
    1. While spindle stopping doing low pressure M code
    2. While spindle rotating doing low pressure M code
    3. While spindle stopping
    a. chuck unclamp in high pressure
    b. chuck low pressure with M code
    c. Chcuk clamp
    Jan 2008
    575
    i don't use the M codes, I use the least chuck pressure possible all the time
    The beaten path, is exclusively for beaten men.
    Feb 2009
    6028
    I have used it in the past, make sure you have the option. The other thing with that system, if it's a stock MMK or Kitigawa chuck, it doesn't really work to well. Works well with the SMW chuck or a collet chuck. We stopped the spindle first, didnt want to take a chance of loosing a part at RPM.
  1. High Pressure Coolant
    By davek11 in forum GibbsCAM
    Last Post: 03-17-2011, 04:08 AM
  2. Replies: 9
    Last Post: 04-05-2009, 05:42 AM
  3. High pressure coolant systems
    By CHAD LAWSON in forum MetalWork Discussion
    Last Post: 08-25-2008, 10:15 PM
  4. High pressure pump
    By LT1TRUCK in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-30-2008, 09:16 PM
  5. high-pressure coolant
    By 307startup in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2007, 10:40 PM
