586,112 active members*
3,139 visitors online*
Page 3 of 3 123
Results 41 to 59 of 59
  1. #41
    Oct 2005
    27
    Hi guys, I'm at Murarrie.
    Seems like there is still plenty of interest around locally. I'd love to have a look at some converted machines to see what's involved as I have a lathe and a mill i'd like to CNC eventually.
    Damo.
    Damen Stevens
    Brisbane, Australia.
    "Measure, then cut, then swear, then measure & cut again"
    http://www.cnczone.com/forums/showthread.php?t=13958
  2. #42
    Jan 2012
    201
    is there anyone on the south side of Brisbane that can come out and work out what the hell is going on with my 6040 CNC Mill
    here is the start of the discussion about the problem and videos (the last 1 realy show the prob)
    things that go bump in the CNC Mill
    i am at acacia ridge
  3. #43
    Jun 2011
    14
    Hi.
    I was wondering if anyone in Brisbane can help with some one off/two off vac-u-form plastic packaging in exchange for beers/cash?
    Its for a custom 1/6 scale action figure (12 inch figure).
    Kind of similar to this:
    http://www.collectiondx.com/gallery2...rsebaian03.jpg
  4. #44
    Jan 2012
    201
    it may not look like much work but you would have to make the molds / formers to do that and that is commercially $5K to $15K worth of work the vacuform machine is the easy part to make its nothing more than a shop vac and a over size oven or you could buy / make one of thes Phlatformer Kit but you still would have to make the molds / formers
  5. #45
    Oct 2005
    27
    Re: Brisbane group
    Time to dust off this thread :wave:
    Are there any Brisvegas locals still around?
    Damen Stevens
  6. #46
    Mar 2008
    267
    Re: Brisbane group
    Hello Metalfab ( Damen),
    still around... still CNCing
  7. #47
    Apr 2007
    80
    Re: Brisbane group
    Quote Originally Posted by Metalfab_101 View Post
    I'm still alive.
    Chrisjh
  8. #48
    Oct 2005
    27
    Re: Brisbane group
    Hi guys. I didn't get to build my gantry machine, but want to give it another crack. It'd be nice to draw on the knowledge of people that have done it before.
    If there is any interest in a local meeting i'm happy to do the legwork to organise something.
    Damen Stevens
  9. #49
    Apr 2011
    7
    Re: Brisbane group
    Still doing some bits and pieces of CNCing on our router (half sheet size).. Dreaming about something bigger also dreaming about a lasercutter.
    Located at Archerfield.
    Cheers,
    Seppo
  10. #50
    Jan 2012
    201
    Re: Brisbane group
    Yep i am still around
  11. #51
    Oct 2005
    27
    Re: Brisbane group
    Nice to see there are still a few around!
    I've setup a group, anyone interested please join that for updates and info -> http://www.cnczone.com/forums/groups...ser-group.html
    Damen Stevens
  12. #52
    Jun 2011
    14
    Re: Brisbane group
    Hello gang
    I’m interested in setting up a plastic injection machine.
    Am inspired by:
    https://preciousplastic.com/en/
    I’ve experience in:
    3d modelling and getting files ready and printed in 3d
    Silicon mold making
    Resin casting under pressure
    Keen to know if anyone else is interested in the same
    John
    North Side of Brisbane
  13. #53
    Oct 2005
    27
    Re: Brisbane group
    Quote Originally Posted by cottontail View Post
    Hello gang
    Am inspired by:
    I’ve experience in:
    Silicon mold making
    John
    Gday John,
    I remember checking out that site a while back, good concept and making those machines is pretty achievable.
    Do you have any interest from a CNC perspective? I'm thinking either recycling plastic for use in a 3D printer or using a CNC router/mill to make molds for injection molding.
    Damen Stevens
  14. #54
    Oct 2012
    5
    Re: Brisbane group
    G'day Gents,
    I'm still alive as well.
    Haven't been here for a long long time.
    I've got a couple of routers I'd like to sell on, new unused, working order.
    1200x1200 & 2400x1200
    Peter
  15. #55
    Jun 2011
    14
    Re: Brisbane group
    Hi Damen
    I’ve actually thought how good it would be to find some sources of recycled plastic in Brisbane for plastic injection purposes.
    To make the molds out of plastic would be problematic am thinking as the molds would need a much higher melting temp than the plastic you are pouring.
    To CNC the molds out of solid aluminium or the like you’d need to be sure there are no undercuts and loops in your sculpt/tool.
    Am keen to talk about CNC molds though...[I don't have a CNC to be honest but I know meshmixer and other 3d programs and have had a bunch 3d printed via different bureaus]
    For DIY purposes I’ve seen that people use aluminium shells and make inserts with epoxy, like:
    https://www.techkits.com/collections/molds/
    It’s all about knowing where your part line in the mold will be. I’m used to making molds out of silicon.
    With silicon you can make 2; 3; 4 plus piece molds if you want to be fancy.
    I’m thinking about getting a plastic injection machine set up and taking it from there.
    Gday John,
    Hi Damen
  16. #56
    May 2007
    15
    Re: Brisbane group
    I'm still here. I have the XYZ cnc kit, running mach3. It's a router but I've added a holder for a hand held plasma cutter. Cutting area is 1500mm x 3200mm. It's way too big but allows me to split big sheets of mild steel before feeding them through the guillotine.
    I'm out at Greenbank (South West side of Brisbane).
    Happy to helpout where I can.
    I'm about to buy Cam bam. I've tried the trial version and very happy with trhe results when plasma cutting. I'm trying to find the time to sit down and do some 3D work in MDF. Any comments good, bad or otherwise regarding this or other cost effective 3d cam processors?
    Cheers,
    Hicks
  17. #57
    Nov 2012
    7
    Re: Brisbane group
    Hi Hicks.
    Mate That is some very large cutting areas.
    Do you take custom work.
    I have been doing things on the side to help people but need a regular cutter / cnc maker to help me with my projects.
  18. #58
    Apr 2007
    80
    Re: Brisbane group
    Quote Originally Posted by hixfixit View Post
    Hi Hicks,
    Have you tried Fusion360?
    I understand it is free for home users.
    The CAM module in it is the same as HSMWorks, which is what I use inside Solidworks. Been using it for years now and very happy with it. Don't have any experience with plasma with it but plenty of CNC milling, lathe and engraving using it's "Trace" function. Trace would work fine with plasma cutting. I'm not aware that it has any nesting function, yet.
    A mate lives in the same street is designing and building a home brew plasma cutter. He is well advanced, and I have been helping out with advice. He will be using LinuxCNC as the controller.
    I'm at Algester, south side near Beaudesert Road.
    Regards
    Chris Humphris
  19. #59
    Oct 2005
    27
    Re: Brisbane group
    Nice to see some Brisbane guys around still. If you're keen to keep in touch with other CNC interested Brisbanites consider joining this group http://www.cnczone.com/forums/groups...ser-group.html
    I'm working on a design for my own plasma table, i'd love to check out what others have built if there's an opportunity to do so.
    cheers,
    Damo.
    Damen Stevens
Page 3 of 3 123
  1. Brisbane laser group
    By dominic gailgan in forum Australia, New Zealand Club House
    Last Post: 02-20-2012, 04:20 PM
  2. Starting Brisbane CNC user group
    By dgreensill in forum Australia, New Zealand Club House
    Last Post: 01-16-2012, 11:54 AM
  3. 5th Brisbane CNC User Group Meeting - 7th Nov 2009
    By ClaudioG in forum Australia, New Zealand Club House
    Last Post: 01-17-2010, 01:41 AM
  4. Brisbane CNC User Group - report on first meeting 7/3/09
    Last Post: 06-15-2009, 10:13 PM
