586,089 active members*
3,982 visitors online*
    Feb 2007
    314
    alpha power supply error code
    At start up, i got 414 424 434 409 alarm. On the power supply, there was an alarm code 01. Wath is exactly. Shut down and restart and everything is ok.
    I alaws got 414 and 424 alarm at start up for about 2 months. Shutdown and restart and alarm goes away. The alarm code on servo amplifier is 2.
    You have a voltage problem...
    01 on the power supply:
    (1) Meaning
    The main circuit power module (IPM) has detected an abnormal
    condition.
    (2) Cause and troubleshooting
    (a) Control supply voltage decrease of the power module (IPM)
    → Replace the power unit.
    (b) Input supply voltage imbalance
    → Check the input power supply specification.
    (c) The specification of the AC reactor does not match the PSM
    in use.
    → Check the PSM and the specification of the AC reactor.
    (d) IPM failure
    → Replace the IPM.
    Feb 2007
    314
    -what is the difference between IPM and PSM?
    -I never change the reactor. How to check if its spec match them of the power supply?
    -Input voltage is balanced and within the spec.
    -How to check the control supply voltage?
    Yesterday I shut down only the control believing that i won't have those alarm next morning.
    This morning, I turn on the control and Beeeep alarm 414 424 434 409(sp=30) and again a 01 alarm code on the power supply. Shut down everything and turn on again. No more alarm. I can continue that way for a while but i know that one day alarm won't go away. But i want to be sure about the cause before replacing component.
    That information that I gave you was taken out of the book. The fact that you are able to run after reset tells me that your hardware is OK. Otherwise you would be fighting other power related issues thru out the day. I would check the incoming power with a voltage meter and watch what happens when you power up. Maybe your contactor that feeds the power supply is not closing all three legs in a timely manner. Check phase to phase to see that all three phases are the same (balance)
    Feb 2007
    314
    Quote Originally Posted by samu View Post
    This day has come!
    Replace the X-Y servo amp and evrything is ok
  1. Cincinnati Milacron Acramatic 2100 Power Supply Failure error
    By Wurmwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-17-2012, 07:53 PM
  2. Fanuc ROBOCUT Alpha-1B will not power on the control
    By TRG in forum EDM Discussion General Topics
    Last Post: 07-04-2011, 09:51 PM
  3. Mini Mill power supply error?
    By plastibob in forum Haas Mills
    Last Post: 07-15-2009, 06:25 PM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
