just got my x2 (for a CNC conversion project) this morning and after dissambly, cleaning, inspection lubrication, assembly and adjustment the z axis gibs are too lsloppy. The head has way too much backlash (horizontal rotational play). I have tried to tighten the gibs even more but it becomes too stiff, too much friction.
I'm converting the x and y axes from gib to pacific bearing PRT (profile rail technology) http://www.pbclinear.com/Profile-Rai...-Linear-Guides and this gave me an idea.
could i use the same linear technology but vertically on the z axis with them bolted to a solid steel riser? This would reduce the amount of friction to the ball screw assembly. These are the two different types I'm considering using
http://www.pbclinear.com/Profile-Rai...-Linear-Guides which is the same as the x-y axes but multiples in parallel or
IVTAAQ Bolt-On Linear Guides - Double Width | Integral V Technology I am considering this method more than the above method.
Any feedback suggestions would be helpful and appreciated...tyvm
