1991 kia st20s with a fanuc ot control, looking for a parameter so the reset button will turn off the spindle in manual mode.also this machine runs the spindle forword with a M04? can this be changed to a M03
there is no parameter for "reset to turn off spindle", it depend on machine tool builder that they allow that or not.
to swap M3 and M4, you could look in the magnectic box to see which relay for M3 (turn on when you command M3) and which relay for M4 then try to swap the coil wire.
How can i get the programming and maitenance manuals of Fanuc 0T series
PM sent.
Al.
Albert E.
Hi where will i get fanuc series simulator?
