Greetings people,
I'm in the process of building a CNC router intended for Oxygen-Butane/Acetilene cutting. It's a hack build, real weird, made mostly out of structural steel using only basic tools and machinery.
The machine is fairly large, I'm going for a 1.5 x 1.5 m (about 4,9 x 4,9 feet) working area. The gantry will travel on Angle-Bearing assemblies propelled via lead screws.
I intend to use 2 stepper motors on the X-axis (3Nm or 425 Oz-in each).
Here follows my dilemma:
Now, keep in mind that I am a hack and an idiot, so I would appreciate if you went easy on me. Here goes, my main concerns are the following:
- First, the main gantry's weight, it's bloody heavy. I figure it's going to total at about 60 kg (132 lbs). I will do my best to eliminate friction but still...
- Second, my lead screws are... well, too big. 24mm major diameter, 5 mm per revolution.
Basically what I want to know is if my motors will be able to even move this thing. I don't have any special requirements as to acceleration. I will be doing some testing, perhaps on Monday but I thought I'd ask you guys before doing anything.
Any thoughts or experiences you can share?
