586,403 active members*
2,875 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Show how to build a CNC machine from the very beginning to the end
Page 1 of 184 1231151101
Results 1 to 20 of 3662
    Jul 2011
    441
    Arrow Show how to build a CNC machine from the very beginning to the end
    Hi guys, I'm a machine manufacturer in this field for years. I have dived in the forum for long time and worked backstage in R&D. some of you guys maybe are using machines with my design or solution.
    This is my first thread and would like to share one of my development works of a small desktop CNC from designing, sketching, mould building, casting, machining etc. to last assembling and testing. Of course it's a formal product project, but I plan to just talk about the technology and building issues in this thread. Any comments and talk on this will be welcomed, I would like to share opinions with you guys in this thread or post message.
    I plan to cover every key step to build the machine including machine structure, part assembling, control and electric system, enclosure etc. I will do every work I can handle by my own hands. So, let's enjoy it and hope everything go smooth...:violin:
    Development aim:
    total around 120KG, about 270lbs--weightness is the best guarantee of stifness and stable precision.
    structure: casting irons of G3000 with heat treatment
    three axis: linear guides with ball screws. considering use a commen class linear system with rolled type ball screws. I think it's enough for most applications.
    axis drive: stepper system / DC servo system. not decided yet.
    spindle: 1.5hp, 24000RPM electric spindle unit with VFD / or considering design a tiny mill spindle system with BLDC motor drive
    electric system: transformer power supply for axis driver and develop a special VFD to support spindle.
    control system: under considering now. should work with MACH software or other cnc software.
    others: plan to add axis covers, enclosures, coolants etc. will update during the thread.
    Jul 2011
    441
    sorry for take some time to update pictures. I've done many designing works before on this machine with every part. the pictures show some process of the works under PTC. Once checked the models with software and soft assembling, we can do the real job then.
    In my thoughts, I planed to make the machine have around 8"*5"*8" travel range, made of casting iron structure and linear guides, ball screws. with VFD controlled electric spindle unit and stepper drive system. Of course, as an option in future, mill spindle system and servo drive system can be also applied.
    So it was designed to a mini precision cnc machine with strong structure. It can handle many material cuttings, from wood, plastic to aluminium, steel pieces. I think some guys may be interested in such small machines. at least it will be a good one for showing building process. I think this thread should be a long term one during my works. I hope you guys can give some comments. thanks.
    Jul 2011
    441
    Firstly is the carpenter works to build the cast mould. The machine structure is not big, so I can work it by myself. I make the moulds using pinewood. It's a little soft and easy to treat. for long period casting process, it's not fitful because easy to transform after long time in high temperature and wet conditions. But for test works, it's no problem, especially after painting.
    Now is the machine base part:
    step1: make the frame of the base. stick the structure together and fasten it with nails.
    bottom:
    add more surface woods:
    get the rough shape of the base now. It still has many longger wood and rough surfaces. but we have to wait until the glue dry and then take next steps.
    The point of making the cast mold is to make the mold slightly bigger than the designed scale. normally, it will need about 1% bigger size because the cast iron will contract with cold after filled into sand molds. And, we can't forget to leave the spare size on machining surfaces. Normally, we need to leave about 0.15" spare size for machining.
    Jul 2011
    These are good drawings, but I doubt this is a good time for honoring made in China machines, while our industry went down the tubes.
    It was the US sending machines and production to China first, paying with massive job losses in electronic assembly and mechanical parts production.
    Fortunately, I can see a gradual recovery in production, new designs and robotics classes in schools. The robotics FIRST competition leads the way in getting our kids exposed to robotics and parts manufacturing.
    Growing up in Germany, I worked on designing steel manufacturing plants, also for Wuhan in China. Some years later our steel industry was dead. Than, I worked on fast pace electronic assembly machines, which is now dead as well with 90% production in China.
    Now, I’m determined to bring production back to the US by teaching the next generation all about production, CNC machines and robotics.
    I know, this is a technical forum, I do apologize for this post.
    Regards,
    Stefan
    Jul 2011
    441
    bottom sceen of the half finished base mold:
    and one more word: When making a casting mold, make sure the side surfaces with a small angle, normally between 1 degree to 5 degree. larger angle will be better to make the cast process easier---easier to remove the mold from sand.
    Jul 2011
    441
    Thank you for your opinions and I think what you said is the reality of the whole manufacture field. And made in China is not a hornor for now. During my career, I often feel headache when facing the selection of many parts and suppliers. Everything gets to be the cost issue and consumable. It’s hard to find a good resource. If you want 10% better part, you need to pay more 100% cost. That’s the reality we are facing. So, as a China manufacturer want to product good machines, we have to balance many issues, and make hard choices. I prefer to work more by myself to make the best balance of every step, banlancing the quality and cost, and designing many parts by myself to avoid homogenization and make best value.
    But, I think from an engineer’s opinion, technology has no difference between countries. I decided to post this thread from a hobbie angle. I tried to make the design as good as it can be, balancing the stifness, compact size, and even beautiful appearance etc.. I will show it step by step in this thread. I want to show different image of a China manufacturer------and a half hobbie.
    Thanks again. Welcome for more comments.
    Regards
    Jul 2011
    441
    The column, work table etc. half finished. The works have been done several days before. I also have finished the last surface fixing and putty works to make the molds look more like wood model works. I will update the pictures tomorrow. Now I'm working on the small fixing and painting works.
    the column:
    stick the bottom to the column:
    the Y axis slider:
    the worktable:
    the head: not sticked together yet.
    the head: half finished.
    okey. the rough building wood works finished here. Next, will be the boring and dirt putty, ground and painting works.
    Sep 2005
    1195
    hi,
    It is nice works. Do you cut that wooden mold using cnc router? I never seen people doing casting details like these here, just keep continue working. I follow your threads here as many other do too.
    Jun 2011
    695
    I agree, this is an interesting build. Looking forward to the "pour".
    Jul 2011
    441
    Quote Originally Posted by asuratman View Post
    hi,
    Thanks asuratman. I don't have a CNC wood router now. All works have been done by hand tools, a electric planer and a electric abrader. So the wood frame is divided to many small pieces to make seperately, and glue them together at last. It's a much more complex work than using a CNC router. I had to measure the scale many times during the work and fix the error.
    Casting process normally is far from our DIY works. We prefer to use materials like aluminium, which is easier to get and can get really nice work with machining. but aluminium is too soft for my machine. Another choice is steel material. But the welded structure has very big stress and cause transform to lose accuracy. So, casting iron is still the best choice for a strong and accurate structure.
    Jul 2011
    441
    Quote Originally Posted by FannBlade View Post
    Thanks for your attention, I will "pour" many details next. and welcome any comment.
    Apr 2006
    169
    interesting build
    keep up the update pictures coming
    nice work:wave:
    Mar 2009
    39
    Hallo Skyfire.This is fascinating.It looks like it will be a great machine.Nothing
    commercial this size currently has linear guides.Can you tell us the weight of the
    castings for head,column and base.Will you also cast the table yourself ?Please
    keep posting.Thanks, Robert.
    Jul 2011
    441
    Quote Originally Posted by hesham morsy View Post
    interesting build
    nice work:wave:
    Thanks, I'm planning to update some pictures today, but found my photo space is used up. I'm looking for another avaliable one now.
    Jul 2011
    441
    Quote Originally Posted by shedbob View Post
    Hi, thanks for your comments. I think this size machine is not as commercial as bigger machines. But it's the machine I wanted to build by my hand for long time. I had some experience on bigger machines and I'm working on them now too. In this thread I want a table CNC can be put on desk and can do some small hard precision works that small routers can't do. The size is just a little bigger than SIEG X2. So maybe you want to build a higher end table CNC, it's fitful plan. Or I think maybe some place like labs, small metal workshop like jewelry etc will need such small but precision cnc machines.
    Sure, I can share the weight. Refering to PTC colculating, the weight are:
    head:12KG / 26.5lbs
    column:15KG / 33lbs
    base: 18KG / 40lbs
    I can't cast the parts by myself. It will need many other resources. I will send the molds to a casting factory for casting parts after I finish them. I think I may take some photos there to share with you guys.
    Jul 2011
    441
    I get another usable photo gallery now. These several photos were taken in the putty works. This process is necessory for fixing small damages and round corners. Sharp corners are not good for casting process. It will cause sand fall down when filling in liquid iron. What's more, it will cause stress in the corner may cause frame transform or even broken.
    Sep 2005
    1195
    It is good for our thread here if you also put some picture of casting process with sand. Si it will be a complete thread that none ever done before in here.
    Jul 2011
    441
    Thanks asuratman, I will complete the whole process here and show many pictures. I think it may take 2-3 month to finish all works. I've done some ground works today after putty dry. I think the painted mold will be finished after 2-3days.
    Jul 2011
    441
    okey, these are several grounded parts. look better now? It's really a dirty and boring work to ground putty off especially from the small corners. but smooth and plane surface is important for casting process. Rough molds are difficult to pull out from sand and often cause bad casting surface, even crack the sand box and make the casting failure.
    May 2005
    1662
    Quote Originally Posted by Skyfire View Post
    If "finish all works" means this mill is fully operational in 3 months it would be a great achievement. Building this machine is currently your main activity ?
    Anyone who says "It only goes together one way" has no imagination.
  1. Show us your machine stands
    By OHLEMANNR in forum Benchtop Machines
    Last Post: 05-05-2013, 03:19 AM
  2. a machine design (pics) from beginning to end
    By blurrycustoms in forum Vertical Mill, Lathe Project Log
    Last Post: 04-25-2013, 02:36 AM
  3. dry build or glue from the beginning?
    By Ezra in forum Joes CNC Model 2006
    Last Post: 10-29-2010, 04:44 AM
  4. Newcastle: Beginning of build plan
    By pippin88 in forum Australia, New Zealand Club House
    Last Post: 09-16-2010, 10:22 AM
  5. Beginning to build my Z-axis.
    By zonk2 in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 06:17 AM
