586,080 active members*
3,485 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Need some help with ball screw installation
Results 1 to 1 of 1
    Jan 2010
    36
    I just received a ball screw along with a fixed and free end bearing assembly and would like some help in understanding the assembly process.
    In particular I’d like to know how the 2 spacers are used in that assembly. As shown in the attached picture there is a small one (5mm) and a longer one (8mm) and both are sized to fit over the machined part of the shaft. What are the uses for either? In other words, why are their 2?
    MY assumption is that the snap ring is used to secure the bearing on the free end assembly even though it came packaged with the fixed bearing parts. Also, there is about 0.010” lateral play in the bearing in the fixed assembly. Is this normal?
    Any help would be greatly appreciated.
    Tom
  1. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  2. roller screw versus ball screw.
    By Paraprop in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 10:21 AM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
