586,094 active members*
4,137 visitors online*
    Jun 2011
    47
    Rings around job in mach3?
    Mastercam has a super charger rotor that im trying to cutout, when I load it into mach3 I get heaps of rings around the rotor, I have mach3 setup to IJ incramental or vise versa, doesnt change anything.
    Also, this part is a bit hard to explane, but the lobes on the blower, in mach3 they are not really joned to the center shaft, sort of floating joined by two passing lines right at the bottom of them, in mastercam it looks fine so I dont understand why its doing that?
    Jun 2011
    47
    This is what it looks like in mastercam
    I am using the correct mach3 post, tried a few others with same or worse results
    Oct 2006
    975
    It almost appears like the Mach orientation is from the end whereas the mastercam view seems to be from a side angle?
    Regards,
    Wes
    Jun 2011
    47
    Thats just the view, tried to move it around so you could see it better.
  1. Distance rings?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 05-30-2012, 02:46 AM
  2. Help a guy and help yourself rails and rings
    By breathe in forum DIY CNC Router Table Machines
    Last Post: 04-10-2011, 02:17 AM
  3. Fixing rings?
    By JayH1119 in forum CNC Tooling
    Last Post: 01-12-2009, 08:43 PM
  4. Fire Rings
    By millerrocks06 in forum News Announcements
    Last Post: 03-31-2007, 09:08 PM
  5. Ferrite rings?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 05-31-2005, 12:43 AM
