586,108 active members*
3,111 visitors online*
Results 1 to 11 of 11
    Aug 2005
    828
    Laser guide to setup parts
    Take a look at this site, toward the end of the first page and on the next page you will see how the router has a laser guide line to show you were to put the slab of granite to be cut. Any one see anything else similar that might possibly be incoperated in to Mach 3?
    http://www.stoneadvice.com/gallery/CNCinmotion?page=1
    Dennis
    35538
    This will project you're g-code file onto your table. http://www.carterproducts.com/produc...id=16&cat_id=7
    Aug 2005
    828
    ^^ That is one cool thing!! But there is no price on the site, so that means it's in K's.
    Dennis
    Aug 2003
    327
    Thats a cool unit. The problem is you need a bit table to get the gantry mechanism out of the way as it projects the image.
    Maybe someone will come up with a projector conversion post one day on CNCZone
    /Mikie
    Aug 2005
    828
    What about the things that were used in school a long time ago to put on the overhead projector to dipslay the computer screen on the wall?
    Any one know what they are called?
    Dennis
    Jul 2005
    42
    transparencies?
    Dec 2004
    518
    Quote Originally Posted by DennisCNC
    Hmmm...let's see...I graduated high school in '80 and at that time there were still no 'puters in my school system. So that would be, what, a long, long, long time ago? We really did use transparencies back then! And we were darn happy we didn't get those stinky blue mimeographed copies. Whew! Now that's old! You young whippersnappers...'puter this and 'puter that.
    O.k, silliness aside, your thinking of the LCD screens that set atop the overhead and displayed the whatever was on the PC monitor. Today there are some real small, relatively cheap, consumer LCD projectors too.
    Sincerely,
    The Ancient One
    Aug 2004
    2849
    Generally the aspect ratio kills the accuracy of displaying the LCD onto a CNC table.
    Apr 2003
    598
    Ovation is the brand of the ones I have. I have several of the panels. Always called them "lcd computer projection panels" every time I found them on eBay...and they always came up.
    -- Chuck Knight
    Oct 2007
    66
    laser projector
    Wow I like the look of the laser projector, might have a go at making one of those, could make a good addon to my plasma machines.
    Cheers
    Mike
    Jun 2008
    1082
    Quote Originally Posted by ViperTX View Post
    What do you mean? A projected picture is not distorted. The pixels in the center of the projection will be nearly-identical in size to the pixels on the outer edge of the projection. The only thing that would make them different sizes would be aberrations in the lenses and the pixels being slightly different size on the LCD(s)/DLP.
    Think of a projector as a reverse camera - when you snap a photo the outer edges of the photo are not distorted (unless the lenses are flawed).
    I think a projector would probably work just fine, depending on how much accuracy you need.
    To make the calculation easy lets say your table is 32" by 18" and your projector is 1080p/i (1920 x 1080 pixels).
    1920 ÷ 32" = 60 pixels per inch
    1080 ÷ 18" = 60 pixels per inch
    So, the greatest resolution you could get in this example would be lines that are ~17 thousandths of an inch thick. I'd say that's enough for lining stuff up by hand.
    The cheapest I've seen a 1080p projector was $1200.
