586,060 active members*
4,592 visitors online*
    Jul 2007
    72
    Need an assist on chamfers...
    I keep getting Alarm 55 (Missing move value in CHF/CNR)
    move distance is commanded less than the corner radius part..
    here is the section Im stuck on now
    #15=.03
    G96S300M4
    Z.2
    G0X[#100+.1]Z.1
    G71U[#1](DOC)
    G71P420Q430U.04W.005F.01
    N420 G0X[#119-[2*#15+.03]] Z.01
    G1X[#119]C-[#15]
    Z-[#127]F.007
    X[#120]C-[#16]
    Z-[#127+#128]
    #2=#120
    The prog. reads N420 then alarms out
    Initially I didn't have the +.03
    I have tried +.1 but still get alarm
    any advice/help would be appreciated
    I'm just a butcher masquerading as a machinist
    Feb 2008
    267
    Make sure that you're in the correct plane (G18 I assume).
    After that, the move after the chamfer needs to be atleast as big as the chamfer itself and in the same direction.
    Too, are you sure that you need the "-" with the C value.
    Though I do not know what control you're using but base on your code, something like this...
    Code:
    G1 Z0
    X.5 C.03
    Z-.05(THIS MOVE NEEDS TO BE AT LEAST AS BIG AS THE C VALUE)
    X1.
    HTH
    Good luck
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Feb 2006
    1792
    Possibly your control does not allow C within G71.
  1. Cutting chamfers and fillets?
    By prestondocks in forum Mastercam
    Last Post: 12-22-2015, 04:21 PM
  2. Can someone make a excel spreadsheet for OD Chamfers
    By SWISS20 in forum G-Code Programing
    Last Post: 07-12-2011, 08:53 PM
  3. Mastermcam x4 and chamfers
    By musicmaneman1 in forum Mastercam
    Last Post: 06-14-2011, 01:22 PM
  4. Naked Edges on Fillets and Chamfers in Rhino
    By spincaster in forum Rhino 3D
    Last Post: 04-05-2010, 11:05 AM
  5. air assist
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2009, 06:48 PM
