i just got a jcut 6090a and here is what i used to setup mine in mach3- no manual with machine
settings for the pins
x =2 dir =4
y =6 dir =8
z =9 dir =7
the spindle is not controlled by mach3 it has a control in the front of the machine
dont forget to set the estop in mach 3 to active low off ...? its a 50 50 chance i got this wrong but you will get it
read the board that has the printer port plugged into it
the next to all the wires going off it it says the pins
2-4-6-8-9-7 thats where you can find the settings if yours is different
i got myne threw ebay and it was from here Jinan Jcut CNC Equipment Co. Ltd
cons about this machine none off hand but the power supply had to small of fuses in it 500w fuse in a 2000w power supply i upped the fuse to 750w
fl3a250v formerly was fl2a250v ---ohms laws for watts is amps times volts 3a*250v = 750w
customs paper work is new to me and it sucked and it costed allot
shipping needed a fork truck to drop off - make sure you make arrangement's to get delivered to your door-you get it delivered by a truck that has a lift in the back-fork truck seems the way to go if you can get to one..my trucker new the people in the area and had one waiting for me in our local industrial area ..they were happy i dropped off a case of beer the next day
pro $2000 cheaper and about 3-$5000 more in worth
instead of its competitors its $2000 cheaper and made of cast iron and not aluminum and has a much bigger work space and industrial not a hobby kit looking at the k2 machines (thanks mandy)
