I bought the RF45 mill about two years ago from Wholesale Tool.
I'm largely self-taught as far as machining goes and I never had the advantage of working in a machine shop, so I can't tell you how good this mill is because I have nothing to compare it to. My machine has probably clocked a total of about 24 hours now, drilling or milling. This is my first serious machine tool.
I've dreamed about CNCing this and have done quite a bit of research along those lines, but would rather get some more experience under my belt. Automating the Z seems like it would be a bear.
I've had none of the leaks or bearing problems some people have reported. I just use plain non-detergent oil in the gearbox.
I've realized of late this mill is always marketed as a "mill/drill", not so much a "milling machine". The subtext I suspect is: "Sure you can mill with this machine in some cases, but if you can't you can at least use it for drilling."
Let me tell you why I am of that suspicion. I find steel much cheaper and easier to weld than aluminum so I fab a lot of my creations from steel.
If I clamp some 1/4 inch mild steel plate to the table and try to edge mill off 1/10 inch with a roughing end mill, and put my hand on the table, I feel almost no vibration. Good. But, if I put my hand on the head there is definitely vibration. Now is the head oscillating 1/32" in either direction? No. But I definitely feel vibration.
Now that I think of it I should have applied the same test to the column. I will follow up on that.
The quality of the cuts is good starting out, but of course I'm using a roughing end mill and the result is --well, rough. I don't use a finishing end mill, but rather clean the edges with a big heavy HF disk sander (which has served me remarkably well for a long time despite what people think of the brand.) Later, I think because of that vibration, the bit dulls and I get reduced travel and a "smeared" looking edge. It just seems to me the bit should last longer.
(I do a lot of edge milling to correct my horrible by-hand plasma cutter cuts. Even with a fence, I have a fairly nervous hand and the results are almost always crappy. In the few cases I have a beautiful cut, its out of square. But I digress.)
Vibration of course equals movement which is evidence of a lack of stiffness. Mind you I know enough to lock the Z and Y jibs and lock the spindle.
I'm running at 210 rpm and my roughing end mill is typically 1" in diameter. It's in a 3/4" R8 collet. Also I'm not climb milling. I mill in the (conventional) direction, whatever that is called.
The cut I described is reasonable, isn't it?
My rate of travel? Well I haven't measured it but I can tell you I don't try to force it. I'm probably putting about 5 ft/lbs of torsion on the X crank. At least 8 ipm but no more than 15 ipm.
Lastly I'm squirting some Tapmatic "Natural" cutting fluid on my cuts when I think it needs it.
Also know that I've learned (in addition to knocking off any dross) to grind off the skin of flat blueish steel that the plasma cutter leaves on the edge of the plate, BEFORE I give the plate to the mill. It seems the plasma leaves a 100th of really hard stuff that is hard on my bits.
Has anyone with a RF45 out there had this same vibration problem? Or is this machine just not up to the task of milling steel? Would a Bridgeport vibrate like this?
Any comments appreciated, even months from now.
