586,096 active members*
3,378 visitors online*
    Apr 2006
    125
    D offset cancel
    Hi Scott,
    Ref the new feature of word address on the pointer.
    We have ours set to display T# H# D#.
    If tool 1 uses offset, then the address will show T1 H1 D1.
    If next tool (say 2) doesn't, the address will show T2 H2 D1.
    I assume the D value will only be updated when it is called again, but can you please look at cancelling at say tool change? That way if comp is not called on the following tool, a D0 is displayed instead.
    Apr 2006
    125
    Hi Scott,
    I trust all is well.
    Have you had chance to look at this please?
    Specifically (for me ), it would be good that when the next tool is called without a D value, the viewport value is blank ie
    T2H2D
    This would be prefereable to a D0.
    Many thanks for the good work.
    Cheers
  1. G66 Cancel??
    By TURNER in forum Fanuc
    Last Post: 02-05-2011, 05:50 AM
  2. How do I cancel a G92 on the fly?
    By Apollopeon in forum Fanuc
    Last Post: 11-05-2009, 07:45 AM
  3. How do I cancel a G92 on the fly?
    By Apollopeon in forum G-Code Programing
    Last Post: 10-31-2009, 09:28 PM
  4. Effect of T0 (tool offset cancel)
    By HuFlungDung in forum CamSoft Products
    Last Post: 09-01-2006, 09:58 PM
  5. tool offset cancel problem
    By zoeper in forum DNC Problems and Solutions
    Last Post: 04-25-2006, 04:46 PM
