586,052 active members*
4,414 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover error- Present sensor lacking
    Aug 2011
    Hi there,
    We have a Biesse Rover A 3.30 K4 and have an error message coming up.
    Error message- PLC9046> Slot tool- present sensor lacking (1 in 52)
    We have started the machine as usual and carried out calibration. We then loaded a program but the machine fails to pick up the tool (diamond cutter)
    We have had the machine drill small vertical and horizontal holes but when the machine went to pick up a tool bit to trim the panel the error appeared again.
    Many thanks
    Dan
    Oct 2007
    4
    you have three sensors in main head you must took a metal sheet that cover them, and you should clean the second or middle, probably is a lot of metal dirt on it but just be careful with it its positioned with micrometers and you should put it back how it was been, and the worst is that is sensor damaged and you will need buy new one
    if you dont find it i can send you picture where to look
    Jan 2020
    Quote Originally Posted by rliovic View Post
    Can you send me pictures were the sensor are at
    Jan 2020
    Quote Originally Posted by For-31 View Post
    Number is 8178813539 send pictures were sensor are at thank you
  1. biesse rover b 4.40 ftk plc 432 error ybn.1.2.6.
    By cutewinuscream in forum Controller & Computer Solutions
    Last Post: 09-04-2019, 07:27 AM
  2. Biesse Rover A3 - PLC error
    By v3rbatim99 in forum CNC Machining Centers
    Last Post: 07-25-2019, 07:24 AM
  3. 3D en Biesse Rover A 3.30
    By larten in forum Spanish
    Last Post: 11-06-2012, 04:01 AM
  4. Biesse Rover 346 "Tool in position sensor"
    By astokely in forum CNC Machining Centers
    Last Post: 11-04-2010, 04:01 AM
