Originally Posted by
LazyMan
Okay I'm wrong there. Yes machines with longer z travel, particularly 5 axis machines do use the rails on z plate, but they also have massive gantry assemblies. On a 5 axis machine, bearing blocks on z plate would simply not be practical. Besides, I really don't see why the bearing trucks have to be spaced any closer in one design vs the other. Both methods have their advantages and compromises. The main problem for me is that if one wants to cut through 3 inches of material with a 3 inch bit, the minimum gantry clearance would have to be just over 6 inches to clear the cutting tool with the rails on z plate configuration but it would only have to be just over 3 inches for blocks on z plate configuration. However, if one has no intention to use long bits than this becomes less important. Either way, I did not mean to suggest that z rails on z plate was wrong way to do it, I was just throwing ideas out there because I went through the same design considerations myself.
