586,061 active members*
4,463 visitors online*
Results 1 to 10 of 10
    Nov 2008
    37
    How To Bend this Tube?
    I'm quoting a job for a customer and need some parts rolled. What type of machine is needed to make the part included on the PDF?
    Attached Files Attached Files
    Jan 2010
    485
    If the tube needs a constant uniform ID, a mandrel type bender will need to be used. Have you searched the Web yet for ready bent tubes that size?
    Jun 2007
    3757
    I just googled these.
    Wood's metal - Wikipedia, the free encyclopedia
    How to bend tubes
    Do good research on prices for the stuff.
    $16/lb looks OK. Beware of high prices. You may find better.
    You will still need to form over a mandrel, but at least the walls won't crush.
    Review tolerances with the customer. Is the 4-place decimal a result of a default CAD setting or is it really necessary and what does it mean, if it's +-.001 you're setting yourself up for headaches & failure because that's unattainable with the tubing called out. The tolerance needs to reflect the standard tubing tolerance PLUS reasonable processing tolerance.
    Nov 2008
    37
    No,the tolerances don't need to be that tight. Just did a rough drawing. The updated specs are below. I looked for a supplier online, but I didn't have any luck. I can change the size if there is a supplier that has something close.
    Thanks for the help
    Jan 2010
    485
    While this isn't the radius you need, they may be able to help you out;
    1.63" Mild Steel, 2.50" Radius, 11 Gauge, 180 Degree Mandrel Bend Columbia River Mandrel Bending
    Aug 2011
    21
    you need the piperoller to do the job
    May 2008
    667
    Quote Originally Posted by deslee View Post
    Or this :cheers::cheers:
    Jeff
    Aug 2011
    21
    Quote Originally Posted by jeffrey001 View Post
    Jeff
    are you jeff chen ?
    Nov 2008
    37
    I did find a place to bend them. The final price was $18.50 each with shipping included. I think this was a fair price. Curious to see what what others would charge for the parts?
  1. tube endforming equipment for telescoping tube
    By DanP in forum Want To Buy...Need help!
    Last Post: 01-23-2012, 11:32 AM
  2. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
  3. Best Way to Bend Aluminum Tube ???
    By twocik in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2009, 07:39 PM
  4. Looking for someone to bend parts!
    By CoolhandLuke in forum Bending, Forging, Extrusion...
    Last Post: 02-21-2007, 04:03 AM
  5. Bend-Tech-ez
    By diarmaid in forum Mechanical Calculations/Engineering Design
    Last Post: 09-23-2006, 05:19 PM
