586,094 active members*
3,926 visitors online*
Thread: Yasnac 3000G
    Sep 2006
    7
    Yasnac 3000G
    I have a 1980 Matsuura 710v w 3000G control. Im trying to punch out parameters from the machine to my pc w/o any luck. I have other machines with a 2000G controls and can send recieve w/o a problem through the rs232.
    Reading some service records i got with the machine, a service guy had to reload all parameters after a battery failure, Im thinking he didnt turn something on in the parameters to enable this feature. Any body have one of these old matsuuras? Im pulling my hair out and its probaly something simple.
    Any info. greatly appreicated.
    Oct 2007
    5
    We have the same machine just bought from an auction. We cannot download a program to or from. It looks like Yaskawa installed an RS232 interface cause we see paperwork with the machine documentiaon. Can you download a program to yours? if so, What the step by step procedure
    Do you need to have the cable plugged in prior to executing Tape in ?
    I know the Pin config is different
    Jul 2004
    173
    This could be a DB25 punch port only on the controller. Do you have a tape reader on the machine? You can try using a tape reader emulator to allow you to load programs into the machine if it has a sanyo tape reader.
    If you need help, just give me a call.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
  1. YASNAC 3000G Parameters
    By stlwrksdesign in forum DNC Problems and Solutions
    Last Post: 03-20-2016, 05:50 PM
  2. YASNAC 3000G Parameters help
    By stlwrksdesign in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-16-2014, 11:34 PM
  3. Yasnac 3000g Startup problem
    By BigBobH in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2011, 10:54 PM
  4. how to dnc a yasnac mx1
    By matosjulio in forum G-Code Programing
    Last Post: 02-06-2009, 10:26 PM
  5. Mpost for matsuura 3000g
    By steelhead1 in forum Surfcam
    Last Post: 10-08-2007, 06:14 PM
