586,035 active members*
3,666 visitors online*
    Feb 2010
    46
    Coolant Ribbon Filter
    Does any one have any information about coolant ribbon filtration or to filter the coolant without losing coolant quality and pressure on outlet up to 100 micron for MPX 620 Lathe or how can Ibuy such device.
    Feb 2009
    6028
    We use a Barnes fabric roller filter. That does the gross cleaning, supplies the coolant pump with ~50 micron cleaned coolant. It then goes through the coolant pump in to a 10 Micron canister filter, then the turret. Not a cheap solution for the average shop, but very very low maintenance.
  1. Help Creating "Ribbon" Surface
    By hst in forum BobCad-Cam
    Last Post: 03-07-2011, 05:57 AM
  2. Haas VMC Coolant Filter
    By Mr.Xtreme in forum Haas Mills
    Last Post: 10-04-2010, 03:05 AM
  3. Need Pink Ribbon Image
    By bikermachine in forum Machine Created Art
    Last Post: 04-11-2010, 05:47 PM
  4. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  5. Changing the Coolant Through Filter
    By donl517 in forum Fadal
    Last Post: 09-18-2007, 11:31 PM
