586,094 active members*
4,034 visitors online*
    Sep 2005
    Koike D10 Troubleshooting
    My Shop Is Using A Plasma Cutter With A Koike D10 Controller.
    As Of The Last Few Days When Cutting Large Circles They Are Coming Out Slight Egg-shaped...any Ideas?
    24221
    cut a line in X & Y and see if one is incorrect length to find out the axis which has the error. Check for backlash or wear anywhere, worn pinion etc, if everthing is tight, the axis may need re-calibrating, ( scaling).
    Al.
    Albert E.
    Sep 2005
    Calibration
    it seems that the X axis is not right, can you walk us through how to calibrate it?
    Kevin
    24221
    You have to have access to the encoder/rev scaling parameter values.
    Use a scriber taped to the torch and jog it to a mark on the machine bed or frame etc. zero out the display and command the machine to travel a set value as far a distance as practical.
    Measure this distance as accurately as possible. Then use the following formula.
    A/B = C
    1/C*E = NEW VALUE
    Where A = The distance the machine display says it traveled
    B = The distance measured by tape etc.
    E = The value that is in the machine encoder multiplier.
    Enter the new (X) value and re-test until the calibration is OK.
    Al.
    Albert E.
