Hello.
I`m trying to make a post-processor for my milling machine, which uses Heidenhain TNC 620 controller. I need some help with drilling cycles. Code looks like this:
Code:
81. Standard drill canned cycle.
seq_only,g_canned_cycle,"200 DRILLING ~"
"Q200=",force_no_add_spaces,initial_plane,default_add_spaces,comment_start,"SET-UP CLEARANCE ~"
"Q201=",force_no_add_spaces,drill_depth,default_add_spaces,comment_start,"DEPTH ~"
"Q206=",force_no_add_spaces,canned_feed_rate,default_add_spaces,comment_start,"FEED RATE FOR PLNGNG ~"
"Q202=",force_no_add_spaces,drill_depth,default_add_spaces,comment_start,"PLUNGING DEPTH ~"
"Q210=0",comment_start,"DWELL TIME AT TOP ~"
"Q203=",force_no_add_spaces,zero_position_z,default_add_spaces,comment_start,"SURFACE COORDINATE ~"
"Q204=",force_no_add_spaces,reference_plane,default_add_spaces,comment_start,"2ND SET-UP CLEARANCE ~"
"Q211=",force_no_add_spaces,dwell,default_add_spaces,comment_start,"DWELL TIME AT DEPTH"
The problematic part is:
Code:
Drill depth is negative value, and my controller need a positive one after Q202. Everithing else is OK. Anyone knows how to make that value positive?
My workaround for now is to change the processed code manually, but I would like to avoid that.
Thank you.
