586,113 active members*
3,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > how to machine through soft jaw on cadet
Results 1 to 8 of 8
    Aug 2004
    15
    Need help to change setting for okuma cadet when machine a through soft jaw.
    thanks!
    Jan 2008
    575
    What "setting" would you change? Write a program for boring soft jaws.
    The beaten path, is exclusively for beaten men.
    Aug 2004
    15
    I have the program, I throught that I need to change the parameter setting somewhere, otherwise the mahine has alarm if I don't clamp something in the jaw.
    when it is not a through soft jaw, I can clamp something in the back of jaw, then machine the front.
    thanks!
    Dec 2008
    3109
    Quote Originally Posted by a00509265 View Post
    You should be machining the jaws in a clamped state, chucks do wear & clamping a part in jaws machined in clamped state would run more true than those machined in a closed condition
    The chuck closed / clamped sensor is on the other end of the spindle, RED light on means OK to cycle start. This is usually set when holding a part, if chuck is open or if chuck closed ( with not part ) should have no RED light - thus stopping an accidental cycle start
    Apr 2009
    1262
    You can do this by changing chuck gripping from OD to ID, but I agree with Superman that you will want a chucking ring to grip on for best results.
    Best regards,
    Mar 2009
    1982
    In my opinion, set of reverse gripping with reduced pressure is good enough. You need to make a taper - counting deformation of work grip. It's 150µm in diameter per (50 ... 60)mm jaw gripping length. You need to experiment and measure at place for best result
    Aug 2004
    15
    Thanks for help, chucking ring works really good.
    Thanks!
    Re: how to machine through soft jaw on cadet
    does anyone know what the chuck proximity switch check is ? ? does anyone have a okuma crown i am experiencing a similar problem where i can't OD grip
  1. Pacer Cadet
    By ianmt36 in forum DNC Problems and Solutions
    Last Post: 08-09-2016, 11:11 AM
  2. Free soft from CAD up to CAM soft
    By Laurent_parti in forum Uncategorised CAM Discussion
    Last Post: 05-15-2013, 04:19 PM
  3. Okuma cadet Mate Machine Time.
    By Gary Emig in forum Okuma
    Last Post: 02-17-2011, 05:35 PM
  4. Cadet Mate
    By Antonio Arguijo in forum Okuma
    Last Post: 08-16-2010, 04:47 PM
