586,036 active members*
3,695 visitors online*
    Jun 2011
    4th axis tail stock
    Hey guys,
    I'm doing a job putting in 4 slots in what we call a piston... we dial the part in to .002 in rotation, but it gets tricky sometimes, as we are just using a typical 4th axis tail stock with a 4" tapered head that goes into the thru hole down the piston. I usually have to end up shimming the inside of it to get it to run true to the .002 (concentric). To me there should be a much quicker and accurate wait of accomplishing this while still using the tail stock...
    are there any attachments on the market that anyone knows about with perhaps fine screw adjustments to "center" the center accordingly to allow the parts to run true?
    I have an idea of what I require and should/could build it, but I dont have time to build one right now, shop is stupidly busy.
    any insight or ideas would be appreciated, thanks
    Jan 2007
    1389
    if you have a hand lathe avail grab the tail stock off the lathe and make a quick mount for your mill table. there adjustable too
    Face mill and counter bore and hole should be simple and fast
    Jun 2011
    re
    We are got 5 more of those parts to do coming up, so I went ahead and am rebuilding the live center for the tailstock. the bearing was shot, so pulled it out, being replaced with an upgraded on, and turned the taper down as it was knackered all to S#!T.
    Should be alot better this time around.
    thanks
  1. tail stock
    By vgilbertson in forum Shopmaster/Shoptask
    Last Post: 01-01-2011, 04:37 AM
  2. Camlock Tail-Stock
    By eartaker in forum Mini Lathe
    Last Post: 10-15-2010, 05:21 PM
  3. Tornado 200 tail stock
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 06-30-2010, 10:40 PM
  4. TAIL STOCK
    By bruiserba in forum Okuma
    Last Post: 12-06-2009, 01:17 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
