586,538 active members*
2,803 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Enroute to Mach 3 cutting problem-seeking advice
    Jul 2006
    18
    Hi guys, ive finally got the machine working and motors calibrated. Im using Enroute to process my Gcode from Flexisign.
    I drew a square 2x2" with sharp corners, but then Mach3 reads the gcode it adds some circle on the top left corner and the sharp edges are replaced by 45dregree angle! Enroute(chair)Mach3. also the X axis cuts 1/16 more than it should be.
    Any advice? Thanks once again for any light that can be shared on this issue.
    Can you post the g-code? And maybe a screenshot?
    Jul 2006
    18
    i hope this link works
    Uploaded with ImageShack.us
    G-code:
    G90
    G0 Z1.
    F300
    G0 X0.9195Y1.167Z1.
    G1 Z-0.
    G1 X3.0928
    G3 X3.3378Y1.3402 I0. J0.245
    G1 Y3.3402
    G3 X3.0928Y3.5852 I-0.245 J0.
    G1 X1.0928
    G3 X0.8478Y3.3402 I0. J-0.245
    G1 Y1.3402
    G0 Z1.
    G0 X0.9195Y1.167Z1.
    G0 X0 Y0
    G54 L12
    Hope that helps, thanks!
  1. Enroute 3 to generate files for Mach 3
    By edmond in forum Uncategorised CAM Discussion
    Last Post: 08-20-2011, 09:52 PM
  2. Seeking advice on GE/Fuji AF-300 VFD
    By jimjovan in forum Phase Converters
    Last Post: 04-05-2010, 02:21 AM
  3. seeking any and all advice
    By kling8 in forum Welding Brazing Soldering Sealing
    Last Post: 02-19-2010, 06:39 PM
  4. SEEKING ADVICE
    By kling8 in forum WoodWorking Topics
    Last Post: 11-19-2009, 09:19 AM
