586,108 active members*
3,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > X in live tool program
    Nov 2010
    My LB15 post generates X as diameter value in code program.
    I am confuse about live tool cycles b/c I program it manually with X has position value (not Dia.)
    In live tool cycles:
    Do we enter actual X position in ZX plane of MCS?
    Or Do we enter diameter value for X?
    The confusion is that I will merge the manual coded live tool cyles into post generated program. So, the problem is X has diameter value in post generated section and position value in manual section.
    Jan 2008
    575
    I enter a diameter always, very rarely use an incremental position. I would recommend programming all the same, and if your post is giving you diameter values, I would manually input that way too. Standardized.
    Robert
    The beaten path, is exclusively for beaten men.
    Apr 2009
    1262
    When G137 (coordinate conversion for face machining) or G138 (Y-axis mode for Y machines) are active, all X values will NOT be in diameter and you will use X-Y coordinates. All other cases they will be in diameter and you will use X-Z-C coordinates.
    So if your post doesn't use dia. values, your machine needs the coordinate conversion option for you to use the G137 and your values to work.
    If you do not have the option, you can put "*2" after your X values and the control will do the math for you.
    If you are going to use cutter comp on the face, you will need to switch planes as well when using G137. Ie: G17, G18, G19.
    Best regards,
  1. Replies: 0
    Last Post: 03-12-2011, 10:11 PM
  2. Live tooling program commands?
    By Blueslinger in forum Bridgeport / Hardinge Mills
    Last Post: 05-08-2009, 08:46 AM
  3. Replies: 2
    Last Post: 12-10-2008, 07:39 PM
  4. O.D. milling with live tool
    By jackson in forum Daewoo/Doosan
    Last Post: 07-02-2007, 02:43 PM
  5. Miyano Live-Tool
    By JerryH in forum G-Code Programing
    Last Post: 10-26-2005, 01:50 PM
