253 ELECTRONICS OVERHEAT
Hey all,
I have been getting this alarm since I bought the machine, a 1996 VF-2. It is not hot in the cabinet, in fact it happens often when the machine is cold. Ya, it does get cold/cool in S. Florida sometimes, a couple of freezes this year.
I researched it some and found that the sensor is located on the main board. It has obviously failed and I might get 50 in one day or zero depending on how the machine feels. May go for weeks then get a bunch in one day.
Mainly affects during jogging or single blocking a program. Can cause weird problems like still being able to jog, but not change axises, which can be a problem when say switching from going down in Z then changing to X and not having it happen.
Someone advised me to check the power supply, but I can't find anything major wrong with it. Checked at 5.01v and 11.95v., but I can't check while running.
I need to find out how to disable this warning, so that it does not throw an alarm.
253 ELECTRONICS OVERHEAT - The control box temperature has exceeded 140° F (60° C). This can be caused by an electronics problem, high room temperature, or clogged air filter.
I would appreciate your assistance.
Cheers,
Mike
