I already have a 6' X 10' table, however, it is too big for my tiny workshop... So, I have decided to try selling it and build a new machine. This time, going for a more modest 5' X 4' gantry. On my current table I am using Mesa electronics boards for the THC and I will again use that same system for the new table and EMC2.
The reason for the new machine... Well, I am using it more and more and it is not in my own shop, so if I have an order, I end up making the toolpaths here, then running across town, cutting a part for five minutes, then coming back to finish it all off. Plus, I think that my friend would like to have his garage back. I had planned to build a new shop here, but I just couldn't get it done this year.
I still have to buy the rack and pinion, motors and drives. Really all I have is the linear bearings and access to a steel shop with all the raw materials and big tools to use. I am planning to use some THK HSR 25's for the main gantry bearings, and V bearings for the other axis. The reason for those choices, is just because I have them. So, there is no point spending a bunch of money I don't have to. I was going to build it similar to just about all the tabletop routers you see, with the center drive under the table for the gantry. The linear bearings will be mounted upside down under the frame, which I hope will keep them clean. With my current table I have to clean my linear bearings all the time, I would like to stay away from having to do that with the new table.
The machine I am currently using will get listed on craigslist. It is well made, very heavy and has a water table and THC. I am going to keep the plasma torch and power supply. Which is an ESAB ESP-50 with a PT-37 torch. It has been working great, is 100% duty cycle and I just don't see any reason to replace it with anything else. So all someone needs is their own copy of Sheetcam and their own plasma torch and they would be up and running. Otherwise, I will have to cover it with tarps and park it outside until I get my big shop built... who knows when that will ever happen.
The plan is to get this thing built and operational within the next month. The sooner the better, I really want it to be functioning and bugs worked out before I get too busy with it this winter.
Next on the agenda is to run over to a friends shop to use Solidworks and get the plans all drawn up.. I hope I can remember how to use that software efficiently... I will post some screen shots when I get them done. Should be this weekend.
