Am building a rolling chain fall to move the RT, vises, etc from the mill table to a wall shelf.
Heaviest projected item is the RT, which currently weighs 150 lb, but will add the stepper motor in the future.
Chain fall, chain, pulleys, etc will be less than 10 lbs.
Using chain rated for 255 lb working strength, following a design I saw one a forum here once, but have never been able to find again.
The overhead beam to support the load will be 5.3 feet long.
Was planning on using 3/4" black iron pipe, as it's easy to come by locally. I know a small I beam would be better, but don't have an easy source.
Is the 3/4" black iron pipe strong enough?
Tom
