586,032 active members*
2,896 visitors online*
IndustryArena Forum > CAM Software > SheetCam > pierce delay doesn't work
    Jul 2011
    48
    anyone else got this problem? i got my pierce delay set to 2 seconds but the torch still runs off as soon as it's lit... how do i fix this? sheetcam generates what seems to be the proper code. "G04 P2" but mach3 ignores it.
    edit: maybe this should be moved to the mach3 sub-forum?
    EDIT2:
    omg you guys are so quick. 100 answers in a few minutes. oh wait...
    (i figured it out so someone can remove this thread now)
    Aug 2011
    Quote Originally Posted by da_Rayman View Post
    EDIT2:
    can you post what you found because i have the same issue.
    thanks,
    Justin
    Jul 2011
    48
    Mach3 reads the G04 code in milliseconds, but this can be changed in the settings menu.
    so for a 2 second delay, you should write: "G04 P2000"
    Aug 2008
    1186
    I don't quite follow, can you make an adjustment in mach to compensate or do you have to manually edit the G04 code line to correct?
    Thanks!
    Aug 2011
    Quote Originally Posted by lcvette View Post
    Thanks!
    i just went to the to config drop down menu and then general logic configuration there is a box on the right hand side with "G04 Dwell in ms" checked as a default uncheck that and it will dwell in seconds
  1. pierce delay in Mach 2 ?
    By Redline in forum Waterjet General Topics
    Last Post: 11-13-2011, 01:58 PM
  2. Pierce Delay even when set to 0?
    By Wolfesmetalfab in forum Mach Plasma / Laser
    Last Post: 02-03-2009, 05:00 AM
  3. Pierce delay and plunge rate settings.
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 07-20-2008, 12:05 AM
  4. Pierce Delay And Plunge Rate
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 01-30-2007, 03:48 AM
  5. peirce delay
    By Redline in forum Mach Plasma / Laser
    Last Post: 09-01-2006, 02:18 PM
