586,283 active members*
4,153 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Having trouble milling narrow slots
Results 1 to 1 of 1
    Jun 2007
    9
    I'm using SprutCAM 7 Pro, Version 7, Build 1.2 Rev 40148.
    I have a part that has 10 identical groups of long narrow slots on 3 sides. I'm trying to setup to mill them all in one setup via a rotary table - simple indexing so it should be no sweat, right?
    Each slot is 0.140in wide with a 0.070in radius end; I'm using a 0.125in end mill to do the cut. I'm using waterline roughing and leaving 0.005in for a finish pass. I'm using a zig-zag entry lead in to get down to cutting depth in the slot.
    The software is behaving quite strangely with this combination of parameters. On 2 sides of the part it successfully generates all 10 slots worth of paths. On the remaining side it only generates 8 of the paths. All slots are identical (I know with 100% certainty they are identical because I did the model and on the CAD side I use a feature mirror to copy them from side to side.)
    Can anyone explain why the program is doing this? It gets really weird with these slots. I'm done parts FAR more complex than this and had less strange behavior. I expected to knock this one out in 20 minutes and I've burned most of day messing around with various strategies and having very little luck ... Argh!
    I've attached a copy of the project. Any and all advice appreciated.
    Attached Files Attached Files
  1. Milling narrow deep slots
    By mdred68 in forum SprutCAM
    Last Post: 05-12-2011, 10:44 PM
  2. Milling slots in 1018 CRS
    By mattpatt in forum MetalWork Discussion
    Last Post: 04-04-2011, 07:08 PM
  3. Milling Deep, Thin Slots
    By divinecnc in forum MetalWork Discussion
    Last Post: 01-24-2009, 05:31 AM
  4. Need some small milling slots done
    By Jeff Wohlt in forum Hobby Discussion
    Last Post: 06-19-2008, 07:34 PM
  5. Milling T-slots in cast tool plate
    By LeeWay in forum MetalWork Discussion
    Last Post: 12-17-2007, 07:52 PM
