586,121 active members*
3,685 visitors online*
Thread: mcam??
    Apr 2004
    124
    mcam??
    Hey, rek'd since your the expert, v9 when i add some new geo. to create some new tool paths to an existing program, it won't post it. everything works ie. regen, verify, but it won't post. any idea's why? If i delete all toolpaths and redo everything then it will post right. Todd
    Aug 2005
    16
    You probably need to right click the operation group (make sure all group ops are checked) click on <Options> then click <Change NCI destination>. So that all your operations are pointed to the same NCI destination. Iam almost positive this is your problem.
    Z
    Apr 2003
    1876
    Quote Originally Posted by ZachB
    Z
    That's the first thing I'd look for. Especially if you've manually changed (or imported) the previous operations. By default, they should be set to the Mcam name.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2004
    124
    Thanks, i'll give ita try. Todd
