586,655 active members*
3,549 visitors online*
    Jul 2011
    23
    ISO post processing
    Greetings y'all!
    I have 1 simple question.
    If I generate ISO code with some post processor in SolidCAM...
    Whether it will be understood by any machine that supports ISO code?
    For example...
    Heidenhain TNC 620 control unit supports both ISO an Heidenhain conversational format code.
    Can I generate code for TNC620 in ISO format with some other ISO pp (4 example "Fanuc")?
    Jan 2008
    20
    as far as i undrstand it, ys it will work. iso is a standard so should work on all iso equipd machines
    Jul 2011
    23
    Your response is welcome, but still I would like to see more replays to my question. I hope that other members who post replay will give me similar answer.
    I'm waiting... xD
    Oct 2007
    499
    The geometry code such as G1, G2, G3 etc. is laid down in the standard (though there are variations) but the code will have machine specific codes that need to be defined in your post processor. For example, how is tool change handled? What turns through tool coolant on? All these sorts of things will be specified in your machine tools manual.
  1. post processing for milltronics ?
    By ihbuilder in forum Visual Mill
    Last Post: 09-16-2011, 11:43 AM
  2. ICAM 18 Post-processing
    By cut_check_cut in forum PTC Pro/Manufacture
    Last Post: 02-15-2011, 07:39 PM
  3. Post processing.....
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 03-22-2008, 07:43 AM
  4. Problems Post Processing
    By L2A3 in forum Dolphin CAD/CAM
    Last Post: 02-04-2008, 03:07 AM
