586,119 active members*
3,580 visitors online*
    Mar 2004
    576
    Angle Sanding Jig
    Actually should be *BUILT* thread... need to sand the edges on some parts regularly and want to keep it jigged up so I won't have to keep re-measuring and changing it frequently, so I built this. The holes in the front plates are for screws to act as stops and I can mount guides to it to keep the part being sanded straight. I'll probably make a new front plate later with the slotted areas on the sides recessed, so I can sand things that are wider than the plate (so the screw heads are not in the way).
    Aug 2004
    48
    Nice work, thanks for sharing.
    Apr 2007
    663
    Nice. Defiantly better than sliced bread. Anything that avoids those time consuming setups, and the inevitable adjusting, makes the world a better place.
  1. Sanding Aluminum - with the grain?
    By tikka308 in forum Material Machining Solutions
    Last Post: 12-20-2017, 05:42 AM
  2. sanding/polishing
    By pk_volt in forum WoodWorking Topics
    Last Post: 06-24-2008, 01:24 PM
  3. Tube Sanding
    By Mark18969 in forum MetalWork Discussion
    Last Post: 01-08-2008, 06:57 PM
  4. Deburring: Grinding vs Sanding?
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 12-09-2005, 08:40 PM
  5. Sanding a mould
    By MBG in forum Moldmaking
    Last Post: 09-26-2005, 06:45 PM
