586,082 active members*
3,650 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Battery change and initializing position _ NL series
    Nov 2010
    I need help ~
    i have a NL series machine and it's battery for NC,SERVO parts was down,
    so i changed it and resetting the absolute position (X,Y,Z) yesterday
    however, when I try to set for 'T' axis today, the problem is that i can not change the status of ZERO POINT SET to 'VALID'
    when I try to change it to 'VALID', the message 'zero point set is already done' is issued, even T axis doesn't set before
    please let me know the way to change ZERO POINT SET to 'VALID'
    or the way to set T axis ~
    Aug 2011
    2517
    if the battery died and you lost all of the parameters you're going to need a Fanuc service man to visit you to re-install everything.
    That's all part of the protection on Fanuc systems and why there are so many undocumented parameters. If you have option boards installed like 4th Axis etc then there's no way to get it working without having the secret option parameters. If you don't have a back-up there's no way to fix it yourself.
    If you have the parameter manual you should be able to re-set most of it and get it mostly working but it'll never be 100% without a Fanuc service guy to do the secret stuff.
    Mar 2008
    31
    This machine comes with Mitsubishi NC. I think best you contact local rep to resolve your turret (T) zeroing issue.
  1. Battery change OSP7000L
    By bengt65 in forum Okuma
    Last Post: 06-17-2014, 03:31 PM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. Change Battery on Maho 600E, Phillips 432
    By Konrad in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-16-2010, 04:28 AM
  4. mtm tool change position
    By double a-ron in forum GibbsCAM
    Last Post: 01-24-2010, 06:29 PM
  5. Help! Dead Series 1 R2E3 battery, need jumper cable?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 10-12-2006, 11:24 PM
